Remote start problems
velocity
Member - Posts: 19
Posted: July 01, 2004 at 10:00 PM / IP Logged
Car: 94 Mustang GT
Alarm: Lynx 2000R
My remote start will start my car for about 5 seconds and then it turns it right back off again. It almost sounds like the engine is started, but the starter is still trying to start it. I could be wrong. I don't know if my car has a second ignition wire or not, because I only have the alarm hookup to one right now. I got the wire IDs from this website, so I am assuming that they are right.
Can anyone point me in the right direction??
Thanks for the help!!!
draasch
Gold - Posts: 2,172
Posted: July 01, 2004 at 10:04 PM / IP Logged
Make:   Ford
Model: Mustang
Year:    1994
This Database Was Last Updated On:    4/7/2004
Index #: 1850
Alarm
Constant 12 volts YELLOW (5) IGNITION SWITCH HARNESS
Ignition 12 volts TAN/WHITE IGNITION SWITCH HARNESS
Starter WHITE/ PINK IGNITION SWITCH HARNESS
Dome Light BLACK/ LIGHT BLUE (+) DRIVER KICK PANEL OR BEHIND GLOVE BOX
Trunk Pin Switch TAN/LT GREEN (-) W/OEM ALARM ONLY - AT PIN SWITCH OR MODULE
Parking Lamp BROWN (+) HEADLIGHT SWITCH OR DRIVER KICK PANEL
Power Lock PINK / YELLOW DR. KICK PANEL IN HARN. BELOW #201
Power Unlock PINK/L GREEN CARPET OR BEHIND GLOVE BOX * #203
* Without OEM Keyless Entry See Note #203, With OEM Keyless See Note #201. #203- See Reversal Rest At Door Lock Diagram. #201- See Negative Pulse Door Lock Diagram.
Remote Start
Tach Signal TAN / YELLOW (5.0 LIT) AT COIL OR PINK AT SPOUT (3.8 LIT) *
Ignition #2 GRAY / YELLOW (2) IGNITION SWITCH HARNESS (HEAT-A/C)**
Ignition #3 GRAY / YELLOW IGNITION SWITCH HARNESS *** #235
Accessory BLACK/ LIGHT GREEN IGNITION SWITCH HARNESS (RADIO/WIPER)
Neutral Safety NOT GROUNDING TYPE - O.E.M. SWITCH OPENS STARTER CIRCUIT
Brake Light GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light BLACK/ PINK (+) DRIVER KICK PANEL
Rear Window Defrost
* SPOUT Connector Is A 2 Pin Gray Plug With 2 PINK Wires Located Behind Air Filter Duct ON PAssenger Wheelwell. ** 2 GRAY / YELLOW Wires Listed Are Same Circuit (Powers Heat/Ac). *** Keeps "ABS" Light Off. #235- See Powering Extra Ignitions Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
velocity
Member - Posts: 19
Posted: July 01, 2004 at 10:14 PM / IP Logged
Thanks for the Wiring diagram, but that is the same as I have. Does anyone know why my alarm would act this way??? OD I have something connected incorrectly??
Thanks!!!
draasch
Gold - Posts: 2,172
Posted: July 01, 2004 at 10:19 PM / IP Logged
have you checked all of your wires?????
do you have the tach wire hooked up????
how dop u have it programmed????
Good Luck
David
Ace Security
813-376-9778
Tampa
snakoiler
Member - Posts: 8
Posted: July 03, 2004 at 9:59 AM / IP Logged
I agree with draasch and I had a similar problem ,maybe your alarm has to "learn" the tac signal assuming you have everything connected correctly. Also some alarms you need to select a lower voltage read setting on the alarm depending on the alarm and car model voltage output on the tac signal if it cannot read the signal, or select no tac signal read on your alarm to see if it stays started
snakoiler
zxhwk
Posted: July 04, 2004 at 9:45 PM / IP Logged
Depending on the type of remote start system you have it wont work untill you program the tach signal then it will work propely (prestige works this way)
hn331
Member - Posts: 16
Posted: July 07, 2004 at 2:13 AM / IP Logged
you might have to reprogram your tach wire.
Always More To Learn!!!
