CSI200 Install on 02 Kia Optima
boostineclipse
Posted: July 07, 2004 at 12:20 AM / IP Logged
Has anyone done this install on this particalur car?  Or any car alarm system on it.  I am lookin for a wiring diagram of the car or just some help from anyone.  Thanks
Shaun
eurotek
Copper - Posts: 58
Posted: July 13, 2004 at 10:50 PM / IP Logged
i have KIA as an account, i do all there cars..  real easy
almost same colors as GM
constant + red
ignition + pink
starter + yellow
when you drop the dash, most pf the following wires are right in front...
the dor lock wires are just to the right side of the ETACS next to the fuse box, in a black plug
lock - white, in a black plug, only white color there
unlock - blue, in the lower plug, black, there are several blues, its the very last one , i suggest you test
door trigger is right below the fuse box facing you, there are two of them, only one is the door trigger
yellow -
parking lights are also in the general area,  i found them to usually be PURPLE / white +  .... sometimes BROWN / white +
trunk release is in the kick panel,
blue +  coming out of door boot...
super easy car.. hardest part is snapping the dash back on...
good luck
