valet code recovery
joeyoone
Member - Posts: 8
Posted: July 21, 2004 at 2:17 AM / IP Logged
The default code for my Clifford Concept 100 does not work. I think I may have changed the code, is there a way to recover the code?
cosmoworks
Copper - Posts: 144
Posted: July 21, 2004 at 2:01 PM / IP Logged
Use the wizard to reset it.
zplatt
Posted: July 22, 2004 at 5:37 AM / IP Logged
I have this problem with my g4 but the wizard asks for the code before it will allow you to access the alarm ECU...and I have the 2.1 pro version!!
sparkie
Platinum - Posts: 2,061
Posted: July 22, 2004 at 7:11 PM / IP Logged
If the valet code on any Clifford product has been changed from default, then the only thing that can be done is to return the main brain to a dealer. They should be able to return it to the manufacturer and have a new micro-processor installed. You will have to pay for this. If the unit isn't a recent model, you may be out of luck as Clifford was bought over by DEI and they don't look after any old product. Most Clifford alarms could be placed inot valet either by the coded valet switch of by pressing the Unlock and option buttons together if my memory is acurate.
sparky
cosmoworks
Copper - Posts: 144
Posted: July 26, 2004 at 11:32 AM / IP Logged
Concept 100 is placed into valet by pressing the two left buttons on the remote simultaneously. (The * and headlight buttons).
swamprat323
Gold - Posts: 1,335
Posted: July 26, 2004 at 8:20 PM / IP Logged
How many code can it possibly have? My guess is 1-9. but not sure on yours. just go through one by one. may have to wait a bit as you go through each one.
swamprat323
Gold - Posts: 1,335
Posted: July 26, 2004 at 8:26 PM / IP Logged
went through the manural----------to many codes
