Programming for Ford PowerCode alarm
alarmgui
Member - Posts: 10
Posted: July 26, 2004 at 3:59 AM / IP Logged
I need to know how to program this thing. It s a Ford PowerCode P/N 2W7J-19A498-AA. Seems to just be an alarm/keyless unit. Need to program remotes and a few features. It has an antenna but also appears to be able to piggy back onto OEM remotes. I am using it as a stand alone unit. Has 3 plugs but only list 2 on label. Wiring was no problem and unit apears to go into a programming mode but I don't know where to go from there.  Label on DNA card says the main unit is a PC12.
Thanks,
Scott
951.532.7464
Scott West
San Jose, CA
NowYaKnow
Gold - Posts: 1,217
Posted: July 26, 2004 at 6:03 AM / IP Logged
1. Open drivers door
2. Turn on ignition
3. Press and hold programming button for 10 - 15 seconds.
4. Release the programming button when the horn beeps 3 times indicating you are in programming mode.
(If it does NOT beep 3 times, do the same process, but with ALL doors closed and wait until the domelights go out. You MUST have the GREEN/ violet door trigger connected to get into programming.)
5. Hit the lock button on any transmitter you are trying to program. If it programs successfully, the horn will beep once. Hit lock on any other transmitters you want to program.
Going into different programming banks just do the same process as above, but after 3 beeps of the horn, press the programming button 1 more time to go into option bank 4, another to go to option bank 5, etc. Each time you hit the button the horn will beep that number of times to let you know what programming bank you are in. Let me know what options you want to program and I will get back to you. Hope it helps,
Mike
alarmgui
Member - Posts: 10
Posted: July 27, 2004 at 3:59 AM / IP Logged
I called 1800 FORD KEY (Audiovox Tech USpport) this monring and they sent me a tree worht of faxes about programming a bunch of systems.
Thanks dude.
Scott West
San Jose, CA
