'03 Sebring Wiring Diagram
alfalfa22
Member - Posts: 23
Posted: August 05, 2004 at 11:45 AM / IP Logged
I'm looking for the wiring diagram for my car 2003 Sebring Coupe. I can't find it anywhere. I can find everything up to 2002, but not sure if it would be the same for my car. Any help would be nice.
extreme1
Silver - Posts: 1,070
Posted: August 05, 2004 at 5:17 PM / IP Logged
12 VOLTS   WHITE/ red + ignition harness
STARTER 1   BLACK/ red + ignition harness
STARTER 2   n/a
IGNITION 1   dk. green + ignition harness
ACCESSORY 1   blue/red + ignition harness
ACCESSORY 2   blue/black + ignition harness
POWER LOCK   purple - driver kick, blk 32 pin plug
POWER UNLOCK   lt. GREEN/ red - driver kick, blk 32 pin plug
DOORLOCK MOTOR   lt. green 5wi driver kick, blk 32 pin plug
DOOR UNLOCK MOTOR   dk. GREEN/ red 5wi driver kick, blk 32 pin plug
DISARM NO UNLOCK   see factory alarm disarm
FACTORY ALARM ARM   lt. GREEN/ black   - driver kick, blk 32 pin plug
These are the door key cylinder wires. Meter the wires while turning the key in the driver door.
FACTORY ALARM DISARM   orange   - driver kick, blk 32 pin plug
PARKLIGHTS POSITIVE   GREEN / WHITE or pink/black + low in driver kick
PARKLIGHTS NEGATIVE    -
BRAKE   GREEN/ orange + brake pedal switch
DOOR PIN   GREEN/ YELLOW   - fuse box
Located in a black 19 pin plug on the back of the fuse box under the driver side dash.
TRUNK PIN   red - driver kick, wht 43 pin plug
DOMELIGHT SUPERVISION   GREEN/ orange   - fuse box
In the plug on the upper right side of the fuse box under the driver side dash.
TACH   white or WHITE/ red   ac test connector
Go to the test connector inside the fuse box under the hood, it is a T shaped plug. Tach is the terminal on the top left of the T, the wire under the terminal is white or WHITE/ red.
TRUNK RELEASE   GREEN / WHITE 5wi driver kick, wht 43 pin plug
SLIDEDOORS   n/a
HORN   lt. GREEN/ black - steering column
Shaughn Murley
Visions Electronics
Red Deer, Alberta
alfalfa22
Member - Posts: 23
Posted: August 05, 2004 at 7:15 PM / IP Logged
Thanks! This will help alot!'03 Sebring Wiring Diagram - Last Post -- posted image.
