2004 subaru outback alarm/remote start wiring
tcool
Copper - Posts: 100
Posted: August 07, 2004 at 4:11 AM / IP Logged
Anyone have alarm/remote start wiring info for an 04 subaru outback? Thanks in advance.
bzzzzttttt
draasch
Gold - Posts: 2,172
Posted: August 07, 2004 at 6:47 AM / IP Logged
see if this info is the same....test all wires with a meter........
Make:   Subaru
Model: Outback
Year:    2003
Alarm
Constant 12 volts WHITE IGNITION SWITCH HARNESS
Ignition 12 volts GREEN IGNITION SWITCH HARNESS
Starter WHITE/ BLACK IGNITION SWITCH HARNESS
Dome Light WHITE/ RED (-) PIN 5 OF A 16 PIN BLUE CONNECTOR *
Trunk Pin Switch YELLOW/BLUE (-) PIN 6 OF A 8 PIN CONN PASS REAR PAN**
Parking Lamp VIOLET (+) BEHIND LIGHT PANEL***
Power Lock WHITE DRIVERS KICK PANEL (SEE TECH) #201
Power Unlock GREEN /RED DRIVERS KICK PANEL (SEE TECH)
#201 See Negative Pulse Door Lock Diagram * Located At The Integrated Module Under Center Console Drivers Side. ** Pin 9 Of A BLUE 16 Pin Connector At Keyless Entry. Keyless Entry Located High In Passengers Side Kick Panel. ***Also ORANGE At Iight Sw Or Pin 11 Of A 12 Pin Connector At Relay Fuse Block Relay Fuse Block Located Under Drivers Dash.
Remote Start
Tach Signal WHT/GRN,WHITE,BLACK RED,GREEN,YELLOW OR BLUE AT COILS *
Ignition #2
Ignition #3
Accessory YELLOW IGNITION SWITCH HARNESS
Neutral Safety
Brake Light WHITE/ BLACK (+) ABOVE BRAKE PEDAL
Reverse Light BROWN / YELLOW (+) AT REVERSE LIGHT
Rear Window Defrost
*OR WHT/GRN,WHITE,BLACK,RED,GREEN,YELLOW OR BLUE AT 24 PIN CONN AT ENGINE CONTROL MODULE LOCATED PASS SIDE CENTER CONSOLE.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
tcool
Copper - Posts: 100
Posted: August 07, 2004 at 4:11 PM / IP Logged
Thanks David!
bzzzzttttt
