What to get for 2 15 Kicker compVR's?
Xgen.m@$t3r
Member - Posts: 27
Posted: August 07, 2004 at 1:32 PM / IP Logged
What kicker amp would be the best to get for 2 15" Kicker compVR's?  It would probably be cheaper to get a kx1200.1 rather than 2 kx400.1's  But I want to see what anyone thinks about which one would be the best to run them with..
Xgen.m@$t3r
Member - Posts: 27
Posted: August 07, 2004 at 1:38 PM / IP Logged
See, If I just get the kx1200.1 then I can run both of the subs fine.. Just more RMS power than I need, but then I only need to run 1 Power wire and such.  So that makes it cheaper than 2 kx400.1's because then I have to run 2 Power wires, But if I get 2 of them then I can strap them together for 800Watts RMS, Instead of 1200RMS off the 1200.1 which is 200watts RMS to much..
forbidden
Platinum - Posts: 5,354
Posted: August 07, 2004 at 2:06 PM / IP Logged
There is nothing wrong with having too much power, buy the one amp and call it a day.
Xgen.m@$t3r
Member - Posts: 27
Posted: August 08, 2004 at 1:26 AM / IP Logged
Ok, well what if I only have 1 Kicker comp and 1 kicker compVR at 4 ohms for each coil, how do I run them so they go down to 1ohm?
robbyrob717
Copper - Posts: 53
Posted: August 08, 2004 at 1:31 AM / IP Logged
if they both are 4 ohm dvc you can wire each sub in parallel (+w/+ and -w/-) on the speaker itself to the terminal and get 2 ohms than wire the two subs in parrallel to get (+w/+ and -w/-) from the terminals in to the amp and you will be at 1 ohm.
94 Pontiac Sunbird 3.1 V6
alpine deck
audiobahn 3.5 fronts w/ tweeters
audiobahn 6.5 rears w/ tweeters
* sold rest of system to save up towards new car. $3000 spent on it.
Xgen.m@$t3r
Member - Posts: 27
Posted: August 08, 2004 at 3:36 AM / IP Logged
But right now what I have is 1 Dual voice coil and one single.. dual 4ohm and a single 4 ohm..
