Opinion’s With alarm Idea
Luvs2Race
Posted: August 08, 2004 at 12:37 AM / IP Logged
Hey I was just wondering when I get my alarm can I hook up the Aux outputs to my bags?? So say i push the Trunk open button it raises or drops the whole truck.  And when I arm it the truck drops and when i dis-arm it the truck rises??
1. For the truck to drop/raise with the aux outputs i can just put a relay and hook it up to all the valves. But the problem is do you think they pulse sent by the alarm will be long enough?
2. Do u guys have ne ideas to make the truck drop when the alarm is armed and to raise when the truck is dis-armed?
Lemme hear some ideas. Thanks.
Luvs2Race
Posted: August 08, 2004 at 12:38 AM / IP Logged
Oh btw it takes the truck a little less than a second to raise/drop
auex
Platinum - Posts: 5,041
Posted: August 08, 2004 at 2:07 AM / IP Logged
Need to know what type of alarm. I have done it before on fast valves.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
kronik66
Member - Posts: 39
Posted: August 08, 2004 at 3:37 AM / IP Logged
you can also use a capacitor and a resistor to adjust the timing of the relay pack. look in the relay section off this site it will tell you how to change pulsed to constant and how to time your relays.
";p
Luvs2Race
Posted: August 08, 2004 at 1:36 PM / IP Logged
I was thinking of getting a compustar pager alarm.
Luvs2Race
Posted: August 08, 2004 at 2:30 PM / IP Logged
Maybe Someting Like this will work??
Opinion’s With alarm Idea - Last Post -- posted image.
tcool
Copper - Posts: 100
With the Compustar programmer you can time your two auxiliary outputs for pulse, latch or timed between 1- 99 seconds.
bzzzzttttt
Joen
Member - Posts: 13
Posted: August 10, 2004 at 1:33 AM / IP Logged
