8-Ohm Speakers
zane9000
Copper - Posts: 69
Posted: August 12, 2004 at 8:39 PM / IP Logged
I know that running speakers with an impedance that is too low for an amplifier is a really bad idea, but what happens if you run speakers that are too high? Specifically I'm wondering if I can run 8-Ohm speakers off my 4-Ohm deck...
You guys must think I'm nuts if you've read all my posts... but hey, doing things the easy way just isnt enough fun!
Thanks,
Warren
I had Cheetos and wine for dinenr.
stevdart
Platinum - Posts: 5,816
Posted: August 12, 2004 at 9:02 PM / IP Logged
Look at Ohm's Law:  if you double the ohm resistance, you get half the power to the speaker.  When setting up a car system with higher load impendances, make sure you have enough power output at the amplifier to overcome the high load.  A deck does not have extra power, so in your case it is not a good idea, although you probably won't harm anything.  You just won't have enough volume.
zane9000
Copper - Posts: 69
Posted: August 12, 2004 at 9:08 PM / IP Logged
Stevdart, what makes you think you've got all the answers huh? Just kidding you always give great advise, and extremly fast answers. Thanks alot.
Kingfisher
Member - Posts: 13
Posted: August 13, 2004 at 11:04 AM / IP Logged
He's right (you already knew that).  You're really not going to hurt anything, but you're not going to get the volume you're looking for.  I accidentally wired a couple of 8 ohm subs in series one time (wasn't paying attention).  I had enough amp that I didn't actually realize I had a problem for several weeks.  My amp certainly ran cool! : )
