Pioneer DEH-P7200 Deck
racer427
Silver - Posts: 381
Posted: August 13, 2004 at 6:27 PM / IP Logged
Hey guy's. a quick question again,
     This deck has 2 sets of rca's. They are split up. One set of RCA's can be set for sub or full range and the other set (according to the manual) is for front channel. I am running both front and rear speakers plus subs with 2 amps. How should I utilize these RCA connections.
    BTW, I am also using a sony XEC-500 indash crossover unit.
Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
louie
Member - Posts: 6
Posted: August 17, 2004 at 10:45 PM / IP Logged
Use your front rca's for your components and the ma 6.5's  you will need a Y cable u're local dealer should have a set for about 7 bucks. Instead of having 2 plug u will get 4 so u can use all 4 channels on your amp.  Be sure your 4 channel amp is 2 ohm stable. wire your tweeter and speaker together and use one channel hold on u're componets should have a lil cross over you could use that and u don't have to wire them together.  Do the same for the other side. Rember to alway check the loads with a multi meter before just to be on the safe side. Then hook up your rear speakers to the rear input on the 4channel amp.  Then just use the rear output on u're deck  convert to sub output and hook up to your subwoofer amp. . U can also sale your old deck and get one with front,rear,and sub outputs. but this should woker i just did an install like this two weeks ago and the guy likes it.
Mac21
Charles_R_H
Copper - Posts: 122
Posted: August 17, 2004 at 11:10 PM / IP Logged
that will work great, but I would consider a deck with all seperate also
electronics run off of smoke, when you let the smoke out they stop working
louie
Member - Posts: 6
Posted: August 18, 2004 at 5:18 PM / IP Logged
I was thinking the same thing that way he can have more ways of controling all the speakers the way he wants to and less trouble. hooking it up . Plus sub control thats anyways nice.  ECLIPSE 8 v pre out
Mac21
racer427
Silver - Posts: 381
Posted: August 18, 2004 at 6:07 PM / IP Logged
I will just leave it wired as it is for now. All head units that I have had in the past has 2 sets of RCA's. One for front and one for rear. This non fading output is new to me but seems to work just fine.
Alpine CDA-9833 HU
Thunder 801D Subs
MTX 1004 10's
4g grounds
racer427
Silver - Posts: 381
Posted: August 18, 2004 at 6:08 PM / IP Logged
The non fading output, does this control the line voltage through the rac's? As it is ajustable.
Alpine CDA-9833 HU
Thunder 801D Subs
MTX 1004 10's
4g grounds
