pioneer head unit install
Bigmaine
Member - Posts: 13
Posted: August 17, 2004 at 3:12 AM / IP Logged
i have a pioneer hu w/cd changer, but i don't have the manual.  Pioneer doesn't really use the standard wire colors.  so how do test the wires to see which is which?
"Intelligence magnifies Ignorance"
fredisfound
Copper - Posts: 60
Posted: August 17, 2004 at 5:59 AM / IP Logged
How old is the unit? Pioneer has been using common wiring colours for a few years now.
raydawg357
Silver - Posts: 769
Posted: August 17, 2004 at 7:11 AM / IP Logged
Sounds like you have an older unit.    Orange = 12v constant,  Red = 12v switched, black is ground,  gray = FR(+), gray/black = FR(-),  green = FL(+), GREEN/ black = FL(-),  GREEN/ red = RL(+) and gray/red = RR(+).   I can't remember the exact color for the (-) wires in the rear, but they are next to the (+).
Hope this helps
Do it right the first time
Bigmaine
Member - Posts: 13
Posted: August 17, 2004 at 12:58 PM / IP Logged
it is an older one, but i'm not quite sure how old. it may be between 4-6 yrs old.  thanx for the help raydawg... but for future reference how would i test them or can I ?
raydawg357
Silver - Posts: 769
Posted: August 17, 2004 at 2:02 PM / IP Logged
If you know what your power and ground wires are, you just have to alternate the other 8 to determine which are the speaker wires,  Adjust the fader and the balance and find  the speaker.   Without knowing your power wires I would 't suggest connecting any type of power to the HU without it going through a 1 amp fuze.  This way if it's wrong the fuze will blow and your HU won't fry.  Have a lot of 1 amp fuzes with you while experimenting.
