need help install alram 2001 civic
hondatech
Posted: September 19, 2002 at 11:05 AM / IP Logged
hey guys i need help on an install on a 2001 civic. I cant get the alarm to lock unlock the door locks on this vehicle, its a predator 2001 alarm and it has 2 wires that send 300ma positive and negtive signal and it just doesnt seem to work, the power doorlocks are positive trigger on this vehicle. i used the yellow/blk for lock behind the fuse box and yellow/grn for lock and they both send positive signal. and the car only has a keyless entry module in it which i left in thanks.
ag
naughtydog
Copper - Posts: 90
Posted: September 19, 2002 at 3:12 PM / IP Logged
If you pulse the unlock wire on the vehicle with a full positive - do the doors unlock??
If they do, then you're 300ma output is not enougfh to drive the original unlock wire. You would need to add a relay as follows:-
30 = Connect to poitive 12V
85 = connect to unlock wire from alarm
86 = connect to poitive 12V
87 = connect to unlock wire on vehicle.
If they dont, you have the wrong wire on the vehicle...
Hope this helps
Naughtydog
kickyride
Copper - Posts: 100
Posted: September 20, 2002 at 11:19 AM / IP Logged
Actually, the power doorlocks on this car should be negative pulse. You have likely found your door lock motor wires. You need to tap into WHITE/ Blue for lock and WHITE/ green for unlock. They will beoth be in a 20 pin connector located in the driver's kick panel. The locks should activate whenever you tap these wires to ground. Hope this helps.
Mike
Mike
Sales/Tech Support - KICKYRIDEoCOM mobile electronics
MECP 1st class-Security Specialist
sador
Copper - Posts: 57
Posted: September 21, 2002 at 10:52 AM / IP Logged
Hi
The problem is that you have the wrong wire you need to used this Power  Lock:WHITE/ Blue (-)
Power Unlock:WHITE/ green(-)
That's what I have on my civic and work fine
