Pro Guard Alarm
sound decision
Member - Posts: 39
Posted: August 25, 2004 at 4:57 PM / IP Logged
I have a customer who pruchased a Pro Guard alarm from canadian tire. everything seems to be working fine except it does not pick up the doors during the auto arming. It just goes into passive arming as soon as you turn the key off. I have tested all the wires and the door trigger is getting right to the brain. We have changed the brain and found it to be the same. I am wondering if anyone has seen this and if there is a fix, or is this just the way it is?
thanks in advance
draasch
Gold - Posts: 2,172
Posted: August 26, 2004 at 5:40 PM / IP Logged
post more info......which wires on the alarm are hooked up to what wires in the car????
what is the yr,make and model of car???
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
sound decision
Member - Posts: 39
Posted: August 26, 2004 at 9:34 PM / IP Logged
Its installed into a ford explorer. its around a 98 or 99. i have hooked up all wires needed. the imobilizer is wired in as is the power locks, flashing parking lights. everything seems to be working fine, except it won't pick up the doors. i'm thinking this thing is more of a keyless entry with an imobilizer, but it says right in the install manuel that it will start to auto ar once the last door is closed. i have tested the wire right at the brain as well. i have even tried the negative trigger just to make sure. and got no response from either.
if any one has any ideas that would be great. i would like to tell the customer whats up with his system. if this is the way it works he'll be ok with it but it would be nice to find out for sure.
thanks in advance
Platinum - Posts: 12,488
Posted: August 26, 2004 at 11:14 PM / IP Logged
The door trigger's on the Ford's are prettty different. What wire did you use for the door trigger ?
daniel2002p
Silver - Posts: 524
Posted: August 27, 2004 at 9:26 PM / IP Logged
you probably need to program that feature into the alarm.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
