Baretta Alarm Wiring Diagram?
Viper238
Posted: September 02, 2004 at 5:55 PM / IP Logged
I picked up a Baretta Alarm new from another installer that was running his own mobile install service...
I was wondering if anyone knows of a Website I can check out to look up some info on this alarm? I didn't get the wiring diagram for the alarm and would like to find out, and maybe some additional information about it..
Xmc Sam
Member - Posts: 19
Posted: September 03, 2004 at 3:57 AM / IP Logged
WHICH MODEL DO YOU HAVE?  M-2, M-4 OR M-5 ADVANTAGE
RED= 12 VOLTS
YELLOW= IGN 12 VOLTS
ORANGE= NEGATIVE WHEN ARMED OUTPUT  (STARTER KILL RELAY)
BROWN= SIREN+
BLUE/WHITE= NEGATIVE THIRD CHANNEL OUTPUT
WHIT/RED=NEGATIVE PASSENGER DOOR UNLOCK OUTPUT
BROWN / WHITE= NEGATIVE HORN OUTPUT
BLUE= NEGATIVE INPUT TRIGGER (PIN SWITCH)
GRAY= SECOND NEGATIVE OUTPUT (TRUNK POP)
PURPLE= POSITIVE DOOR TRIGGER
GREEN= NEGATIVE DOOR TRIGGER
CALL ME AT (661)733-0342   (SAM) AND I WILL FAX YOU THE OWNERS MANUAL
WE INSTALL ABOUT 300 BARRETA ALARMS A MONTH, HAVE HAD MINOR PROBLEMS WITH L.E.D LIGHT BURNING OUT, OTHER THAN THAT ITS BEEN A GREAT ALARM SO FAR.
I NEED TO KNOW WHAT MODEL YOU HAVE FIRST
newinstaller
Copper - Posts: 160
Posted: September 03, 2004 at 11:19 PM / IP Logged
I have it aswell
I am in Toronto
Let me know
Viper238
Posted: September 15, 2004 at 5:34 PM / IP Logged
It's the M2000..
I was hoping it had unlock and lock outputs..
after the wires here. I have 3 wires left on the brain..here
white -  (prefused - 10A)
BLACK/ white -
black - (I'm assuming ground)
Thanks again..
Xmc Sam
Member - Posts: 19
Posted: September 16, 2004 at 2:06 AM / IP Logged
WHITE= POSITIVE PARKING LIGHT OUTPUT
BLACK/ WHITE= NEGATIVE DOME LAMP SUPERVISION OUTPUT(MUST USE RELAY)
BLACK= CHASSIS GROUND
By the way, there was a fellow from the U.K that left a message on my voicemail the other day, I tried to return the call but for some reason the phone # didn't work. I even called my long distance carrier and they said i had the right country code and all so i'm assuming the # was just wrong. Any way, call me back if you still need help or email me at SAMUELIBARRA@MSN.COM
