Need Help To Install Two Amps w/ 4Subs
telezz
Posted: September 06, 2004 at 3:38 PM / IP Logged
Can someone please help me out ?
I have a pioneer DEH-6500 with one output to aplefier and i had two subs (10' Alpine 600w) connected with Sony XPlod 1200w now i have another amplefier (Legacy 2x600) with two Sony xPlod Subs (12' 1000w) I was wondering how will i link both Amps ? Should i pass two more wires ( 12V + Ground ) From the battery ? Or can i juxt plug them in the first's amp's 12V and Ground ? As well as the input , i only have one output in the stereo .. how will i plug the 2nd amp to it ?
Please someone help !
stevdart
Platinum - Posts: 5,816
Posted: September 06, 2004 at 4:25 PM / IP Logged
For one, use a distribution block for power.  Make the one wire from the battery large enough to accomodate the power requirements of both amps ( I'm not looking up their specs...), and the distro will distribute to a number of amplifiers.  Found everywhere car audio is sold.  That answers the next question, too.
You should have a full range output on one of the amplifiers to pass the signal into the second one.  If one of your amps do not provide it, you will have to use Y-cables to split the signal to the amp inputs.  Found everywhere car audio is sold...
Ketel22
Silver - Posts: 976
Posted: September 06, 2004 at 7:13 PM / IP Logged
running the different types and sizes of subs will run you into some technical problems and loss of possible spl that you may or may not care about.
Quad L Handyman services
pimpincavy
Silver - Posts: 880
Posted: September 06, 2004 at 10:01 PM / IP Logged
Running a setup like that, with differant sub types, and amp types isnt ideal. But try it, you might be very happy with how it sounds.
