connecting door locks on Clifford alarm
CutlassThunder
Copper - Posts: 68
Posted: September 26, 2004 at 3:21 AM / IP Logged
I'm trying to hook up my Clifford G4 alarm to the power locks on my car(84 Monte Carlo), which unlock wires do I chose I have a set of unlock/lock wires for common, a set for normally open and a set for normally closed, which door lock do I use on my car?
CutlassThunder
Copper - Posts: 68
Posted: September 26, 2004 at 11:02 AM / IP Logged
I'm trying to hook up my Clifford G4 alarm to the power locks on my car(84 Monte Carlo), which unlock wires do I use for this application?
I have 3 sets to choose from.. a set of unlock/lock wires for common, a set for normally open and a set for normally closed, which set do I use for my car?
CutlassThunder
Copper - Posts: 68
Posted: September 27, 2004 at 10:07 AM / IP Logged
I need help A.S.A.P. these are last few wires to connect...to word what I said clearly. I have a 1984 Monte Carlo SS, and a Clifford Intelligaurd Millennia alarm...I'm trying to connect the alarm to the power locks on my car. the alarm has 6-wires(3 sets of 2) labeled for power locks... 1 set is labeled unlock and lock wires for common, the 2nd set is labeled unlock and lock wires for normally open, the 3rd last set is labeled unlock and lock wires for normally closed. How do I connect this alram to my Monte Carlo?
Platinum - Posts: 12,488
Posted: September 27, 2004 at 10:36 AM / IP Logged
Here's what you need:
  • Common 30 - Goes to UNLOCK wire
  • Common 30 - Goes to LOCK wire
  • N/O 87 ( BOTH ) - go to 12 volt + fused at 10 amps
  • N/C 87a ( BOTH ) - NOT USED
