02/03 Grand Am Monsson into 97 Firebird?
lt4firehawk
Posted: October 01, 2004 at 11:01 AM / IP Logged
Ok, here's the deal.  I've got a 97 FIrehawk (Firebird) w/ Monsoon system in it.  This uses the standard GM wiring interface from the 90s.  I would like to fit an 02/03 Grand Am Monsoon head unit (w/MP3) into this system.  Does anybody have a wiring diagram for the new Monsoon head units or know where I can find one?  I know, why bother doing all this work to keep a stock system, but I would like to keep a factory look while gaining the MP3, 8 band EQ, and CD/Cass capabilities of the newer head unit.
mo12v
Posted: October 01, 2004 at 10:28 PM / IP Logged
I beleive the 2003 Grand-Am Radio is a DATA type radio which goes thru the Body Control Module & U would find it pretty hard to get it to work with your 97
MO
awilliams64
Member - Posts: 40
Posted: October 02, 2004 at 10:04 PM / IP Logged
i dont think it will work at all for the above mentioned reason and also it is a different size, it wont fit in the dash of the older car
lt4firehawk
Posted: October 03, 2004 at 10:02 AM / IP Logged
I didn't realize it was a different size, is it double din instead of the 1.5 din in the older GM cars?  Oh well, I went ahead and found another solution anyway.  Thanks for all the info.
