1995 LeSabre alarm/keyless wiring info
computermole1
Posted: October 01, 2004 at 12:48 PM / IP Logged
I need the wiring info (color location) for my 1995 buick lesabre.  I am going to be putting in an alarm/remote start/keyless entry system in it.  Any help would be greatly appericated.
thanks,
dave
mo12v
Posted: October 01, 2004 at 10:23 PM / IP Logged
This what I have:
Constant 12 voltsRED AND REDIGNITION SWITCH HARNESS *
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightDARK BLUE (-) DRIVERKICK PANEL OR WHITE @ COURTESY LIGHT
Trunk Pin SwitchORANGE / BLACK (-)TRUNK LIGHT OR TRUNK LID LATCH SWITCH
Parking LampBROWN(+) AT LAMP CONTROL MODULE
Power LockLIGHT BLUEDRIVER KICK
Power UnlockWHITEPANEL
* Seperate Circuits, Both Fused At 60 Amps.
Positive Pulse Door Lock   Custom Series, Limited And Limited Select Series All Have OEM Keyless Entry Standard
Accessories
Window UpD\ D BLU P\ D BLU/WHT D\ D GRN P\ L GRN @ MAIN SWITCH
Window DownF/ GRY F/ TAN R/ VIO R/ VIO
Ign Key WarnLIGHT GREEN(-) STEERING COLUMN HARNESS
Trunk ReleaseBLACK (-) RELEASESWITCH OR LT BLUE AT VALET SW.
OEM HornBLACK (-) STEERING COLHARNESS OR AT RELAY-OUTPUT-DK GRN (+)
HeadlightsYELLOW (+)LAMP CONTROLMODULE OR BEAM SELECT SW.('95 BLUE)
OEM Alarm ArmN/A
OEM Alarm DisarmLIGHT GREENIN EITHER KICK PANEL
Reversal Rest At Ground Power Window Circuit
* Trunk Release Also Found As BLACK/ WHITE (+) In Driver Kick Panel.
 Negative Trunk Release
Remote Start
Tach SignalWHITEAT IGNITION MODULE *
Ignition #2ORANGEIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryBLACK OR BROWNIGNITION SWITCH HARNESS
Neutral SafetyORANGE / BLACK - SWITCHON TRANSAXLE OR TRUNK RELEASE SWITCH
Brake LightWHITE(+) SWITCH ON BRAKE PEDAL SUPPORT
Reverse LightLIGHT GREEN (+)SWITCH ON TRANSAXLE OR REAR BODY HARN
Rear Window Defrost
* Ignition Module Located On Top Passenger Side Of Engine. V.A.T.S. Standard On 1995 Models.     - VATS
MO
