2000 Pontiac Sunfire VSS Wire
tj2131
Posted: October 02, 2004 at 11:43 AM / IP Logged
I need help finding where and what color the VSS wire is.  I need to find it for a navigation system, can I find it near the Cruise control box.
I read a few places that I can find it there, but I've been told two different things on what color the VSS wire is, GREEN / WHITE or purple.
If its not by the cruise control can ypu please tell my in English terms where it is located,
Thanks,
Tristan
mo12v
Posted: October 02, 2004 at 11:58 AM / IP Logged
Between Tire & Headlight, Passenger side, 80 Pin Connector  Position 16 GREEN / White wire   4000 PPM
Take 7mm screws out from under wheel well and under front bumper (passenger side)  Pull plastic wheel well loose.  It is under there
MO
tj2131
Posted: October 02, 2004 at 12:31 PM / IP Logged
It there, boy they really hide theat thing, why do they put it there. I have the 2.4L engine if that makes a difference, I looked under the dash and I did find a GREEN / WHITE wire the a white wire.
But I willgo out now and see if it is where you said.
Thanks,
tristan
tj2131
Posted: October 02, 2004 at 12:56 PM / IP Logged
I just got in from looking yep its there I saw a bunch of wires and I did not have enought time to take the whole plastic piece off because it raining and trying to find ther wire was driving me nuts, but Im pretty sure its there.
IM going to take a better look tomorrow when its dry.
THANKS
Tristan
sparkie
Platinum - Posts: 2,061
Posted: October 03, 2004 at 3:36 PM / IP Logged
The VSS wire can be found in the bottom side of the large connector plug next to the driver's side shock tower. The wire is GREEN / WHITE in the corner of the plug, but it doesn't come through to the top. It dead ends in the bottom side. If you remove the battery and aire box, you can easily get to it and make a good connection.
sparky
