96 Nissan Altima remote start
briandors
Member - Posts: 45
Posted: October 15, 2004 at 8:39 PM / IP Logged
Accessory isolated.
I think/hope the only problem left is the SECURITY light/system.  Even as the r.s. powers up the dash, the security light is still on.  Normally as soon as the key hits accessory it's off.
I looked at the wiring diagram for (-) disarm in the installation manual.  It says:
85 to r.s. brain disarm output
87 to ground
87a doesn't look connected?
30 to car disarm wire (GREEN/ YELLOW, but i'm not sure which one and how do i test this with a meter?)
86 to +12V
So the questions are, does 87a go anywhere? and where is the correct GREEN/ YELLOW?
I can tell I'm so close, thanks for everyone's help.  Need to wrap this up tomorrow. :)
Brian
shortcircuit
Member - Posts: 8
Posted: October 19, 2004 at 1:53 PM / IP Logged
Brian, did you get everything working now? I'm planning on installing remote start add-on Crimestopper RS-901 on '98 Altima GLE. I have factory alarm too. I do have factory service manual on the electrical for a '95 Altima. Email me at fsgunawan@yahoo.com, I can send it to you. It's rather big (4.6 Meg). I did a bit of a check, it does mention WHITE/ Blue for accessory.
shortcircuit
briandors
Member - Posts: 45
Posted: October 19, 2004 at 2:14 PM / IP Logged
WHITE/ Blue is definitely correct.
It is starting now.  But starter grinds when you stick the key in and turn to ignition on (no i'm not turning to Start).  I have been told this means I need to isolate the starter wire.  DEI's tech notes say isolate accessory.  That's where I'm at.  Do I isolate both?  Just starter?  I did accessory only and that didn't help, I did main start also, still grinds.  Now one guy says all I should need to isolate is cold start.
It seems nobody knows the 96 Altima well enough. :(  I will email you.
