crossovers
adamaudio77
Member - Posts: 12
Posted: October 14, 2004 at 1:46 PM / IP Logged
ok here is my question ive been an istaller for a long time and feel kinda stupid asking this but here it goes.  what happens to the xover's slope and f3 if you combine two active xovers together like an EQ/Xover like my EQX wich has a 24db slope and an f3 at 90 hz with an amp that has an active xover with the same slpoe and f3.   or if thay are miss matched  like 12db /80hz with a 24db/90hz  do thay combine to a steeper slope  and what about the f3 does it change?  like I said Ive been installing for a long time and understand xovers in their normal application very whell, but have allways wondered about the effects of daisy chainning them. I have read so many books,magazens,and other stuff on xovers but thay never say what happens when thay are daisy chained.  SO if you know and would like to share your secrets with me plese respond. I am always looking to ferther my education and believe you can never know too much  I,ll stop learning when Im dead.  thanks for your time!
    **adamaudio77**
my DMM is my best friend
stevdart
Platinum - Posts: 5,816
Posted: October 14, 2004 at 4:38 PM / IP Logged
If a signal goes through an active crossover, the signal has changed.  The -3 db cutoff freqency (f3) also has changed by using the crossover.  If that signal then goes on to another crossover, the new crossover is added to the existing one.  It will change the curve and therefore the f3.  If you add another crossover, it too will be added to the existing ones.  The f3 changes with every change in crossovers.
You could download WinISD and do some experimenting with crossovers.  You can add several crossovers to a project and select however many you like, and you'll see the slope change with the addition or subtraction of the different ones.
I'm just barely familiar with crossovers, but I've gotten that much knowledge by working with WinISD on my own speaker projects.
adamaudio77
Member - Posts: 12
Posted: October 14, 2004 at 11:21 PM / IP Logged
crossovers - Last Post -- posted image.
it just so happens that i allready have WinISD but i havnt played with the xover function that much i didnt know you could apply them to the box curve. thanks for the good idea. when i said f3  i ment the point were the high and low pass signals crossover not the -3db natural foll off of a speaker/box combination wich is also called f3 refer to the crued pic. i put up. thanks for the reply!
    **adamaudio77**
adamaudio77
Member - Posts: 12
Posted: October 14, 2004 at 11:31 PM / IP Logged
pic didnt work ohwell  i hope you understand what i ment by f3 it has two applcations. The minus 3 db point of the natural speaker/box roll off and the point were the high pass and low pass xover slopes cross wich is also minus 3 db and called the f3 of the xover and  is also the freq. of the xover were this happens.  so hard to explain.
    **adamaudio77**
stevdart
Posted: October 14, 2004 at 11:35 PM / IP Logged
You would have to add .jpg to your picture to upload it, so we don't see it.  But I know what you're referring to.  Pick one of the subs in the programs data to work with, then bring it up twice as a new project.  Put a highpass filter on one, and a lowpass filter on the other.  The graph will show both filters used.  Then you can select different crossovers for each one and watch the difference in the graph.
Actually, they don't cross at the -3 db point.  The lines cross at a point near the top of the slope (near 0 db) for a smooth rolloff and minimal loss of frequencies.
