2003 gm sierra
partyguy
Member - Posts: 30
Posted: October 16, 2004 at 8:36 PM / IP Logged
i installed a r/s on a 2003 gmc sierra the start works great but it will only start if the doors are unlocked i recently installed a r/s on a 2002 and had no trouble but the difference between two is i did not install the keyless because of the headache. i'm planning on lookin at it tomorrow my question is does the factory disarm wire have anything to do with this?? any input on this guys??
mo12v
Posted: October 16, 2004 at 9:19 PM / IP Logged
Did U hook up the DisArm wire:
OEM Alarm DisarmLT GREEN (-)AT DOOR MODULE INSIDE DRIVERS DOOR
OR
There is another wire elsewhere, maybe someone will post it
MO
partyguy
Member - Posts: 30
Posted: October 16, 2004 at 9:22 PM / IP Logged
no i did not i thought ya only needed it if you were adding aftermarket keyless entry was i wrong to assume this?
mo12v
Posted: October 16, 2004 at 9:33 PM / IP Logged
Usually, that is why it starts with doors UNLocked (DisArmed)
MO
partyguy
Member - Posts: 30
Posted: October 16, 2004 at 9:35 PM / IP Logged
right on that must be a difference from the 02 cause i never has that prob but i did have to go in and hook up the wire for keyless thanks fro the help mo.
mo12v
Posted: October 16, 2004 at 9:47 PM / IP Logged
MO YO !
MO
