Single wire system on 2003 grand am se1
mo12v
Posted: October 22, 2004 at 4:18 PM / IP Logged
What exactly R U Installing??
If just Keyless Entry, then U do NOT need Combo unit.
If Remote Start / Keyless Entry, then U should use Combo unit
Don't get me wrong..........U do NOT need either to complete install of RS or KE, but it sure is easier (and maybe cheaper, for someone that does not install everyday) on the install
MO
ray0266
Member - Posts: 14
Posted: October 22, 2004 at 4:32 PM / IP Logged
I'll be installing the pheonix digital pd-175. My car has the factory keyless entry on it. i am going to install alarm, remote start, keyless entry, trunk release. and the accessory wire for the ac/heat (which remote start run ac/heat for then minutes). the unit is one of those two way fm alarms bought from asianwolf.
regards
mo12v
Posted: October 22, 2004 at 4:39 PM / IP Logged
O.K.
U should use Combo DATABuss Interface that does the whole enchilada........
Easy hook up (if U can follow instructions ) and 1 wire that hooks to your Purple wire on the OBDII plug under dash, which will control all functions via DATA
MO
ray0266
Member - Posts: 14
Posted: October 22, 2004 at 4:43 PM / IP Logged
that's exactly what i need. could you recommend a unit and where to get it online.
mo12v
Posted: October 22, 2004 at 5:33 PM / IP Logged
As in previous post:
We sell the MULTIDL for the 1999-2004 Grand Am for $ 65. USD shipped. Easy to install and great system to work with as far as programming goes.
___________________________________________
Support the12volt.com please donate to the site
Got Questions?...Contact Tech Support
OR
Don't know where U R located, but U could call 1-888-921-8324 or http://www.caralarm.com  and ask if they have a dealer in your area or I could sell you one
MO
ray0266
Member - Posts: 14
Posted: October 22, 2004 at 5:54 PM / IP Logged
how much the unit would coast?
