box building formula
kevin1488
Member - Posts: 26
Posted: October 22, 2004 at 9:57 PM / IP Logged
What is the formula again for figuring out the square feet of a box that has a angle in it like 19"h X 52"w X top 4"d X bottom 8"d
what is the formula that you times then divide for the top being 4" and the bottom being 8" i hope this makes sense
stevdart
Platinum - Posts: 5,816
Posted: October 22, 2004 at 10:28 PM / IP Logged
box building formula - Last Post -- posted image.
A couple of different ways.  Look at the Volume Calculators.  Go to wedge 2, and turn your box on its side so that it looks like the diagram:  height 1 is 8", height 2 is 4".  This calculator figures interior space when you measure outside dimensions and input the wall thickness.
Wedge 1 and Rectangular calculations can be combined, because if you draw a straight line down from the top you'll have a simple wedge and a rectangle.
If you measure interior dimensions, you can use the equation:  1/2 base X length X height for the wedge, and the regular W X L X H for the rectangle.  For either of these, you get cubic inches, which when divided by 1728 gives you cubic feet.
kevin1488
Member - Posts: 26
Posted: October 22, 2004 at 10:42 PM / IP Logged
i guess i am lost here i found a site that had some other way to do it that added the top dimension and the bottom dimension and divided it by 5 or something and that have gave that number to be added into the equation
stevdart
Posted: October 22, 2004 at 10:55 PM / IP Logged
Leaving the calculators out of the picture, if you gave interior dimensions of your box in your first post, then divide the box into a wedge and a rectangle as I showed above.  The wedge would be 1/2 base X length X height:  2 X 52 X 19 = 1976 cu. inches.  The rectangle would be 4 X 52 X 19 = 3952.  Add the totals = 5928.  5928 divided by 1728 = 3.43 cu. ft.
