2004 Honda accord alarm/remote start
link123
Member - Posts: 21
Posted: November 14, 2004 at 9:51 PM / IP Logged
Ungo RS151 remote starter
HODL2 (Door lock alarm interface)
PHK3 (Immobilizer)
These are the items that I used to install in a 2004 honda accord V6.
Problem:  The vehicle will start with remote starter, but the factory alarm will sound.  This 2004 has a key that has the lock/unlock on it.  If I use to lock and then unlock with the this key then the factory alarm will not sound.  When I lock vehicle  with the factory key or the ungo remote, and I use the remote start on the ungo, the will factory alarm will sound  or when  I unlock using the ungo remote it will also sound.
My understanding that if I use the HODL2, when I unlock it should disarm the factory alarm.
I thought that hooking the HODL2 will take care of the factory alarm because it drives off the lock and unlock.
 Is this not true?
Anyone has experience using the HODL2 and working on this particular vehicle?????
What do I need to do to correct this problem??
link123
Member - Posts: 21
Posted: November 15, 2004 at 8:54 AM / IP Logged
 Anyone?  I know there are lots of folks that worked on honda's!
link123
Member - Posts: 21
Posted: November 15, 2004 at 2:53 PM / IP Logged
Hello?????
profuse007
Gold - Posts: 2,015
Posted: November 15, 2004 at 4:19 PM / IP Logged
|FCTRY ALRM DISARM|white               |- |driver door module in door
youll need a wire that will disarm when unlock w/ the UNGO and when remtoe start.
Houston,TX
