No climate control with remote start?
berusch
Posted: November 17, 2004 at 10:12 AM / IP Logged
Hi,
Just had a Viper 791 installed in my 92 Mercedes 400E at an authorized Viper dealer.  I am told that I can not have climate control when the car is running with the remote start.  Other power options in the car do work under remote start (windows, rear defrost, etc).
Also, I purchased the proximity sensor, which was hooked up instead of the shock sensor.  I was under the impression both sensors could be hooked up together, which is what I wanted, but am told otherwise.
Can anyone shed some light on this?
Thanks, Ben
berusch
Posted: November 17, 2004 at 10:19 AM / IP Logged
Also --
Just noticed aftermarket alarm will arm the factory alarm, but does not disarm it.  So if I remote start while locked/armed the factory alarm goes off.
Please help....
Thanks, Ben
AutoAcoustics
Member - Posts: 11
Posted: November 17, 2004 at 10:53 AM / IP Logged
Sounds to me like you need to take your car back to the installer.  The prox and shock sensor can be used together.  The aftermarket alarm is supposed mto disarm you factory alarm.  And you should be able to have climate control.  After all, isn't that the whole point of remote start?  I'd say take it back, and if they can't fix the problems ask for your money back and take it to someone who knows what they're are doing.
TJ92Civic
Copper - Posts: 161
Posted: November 17, 2004 at 1:44 PM / IP Logged
Yah i agree with AutoAcoustics.  There may be more than 1 accessory wire that needs to be powered up for the climate control to work.  And there should be a factory alarm disarm installed also.  And you can install both sensors, just have to diode them.  I saw a link how to do it, but I can't remember where it was.  It was in someones signiture.
Good luck.
Tim
berusch
Posted: November 18, 2004 at 10:05 AM / IP Logged
Thanks for the replies, but that wasnt exactly what I was looking for.  I am quite capable of handling my own business affairs.  And before I get angry--and get the guys who will be working on my car angry--demanding my money back, it's better to give them a chance to correct the issues.
What I am looking for is installer's experience.  If you've put a remote start in a 86-94 W124 Mercedes (300E,400E,500E,E320,E420,E500) please let me know if the climate control worked.  If so, how did you do it.
I called Viper, but the techs won't talk to a consumer for "insurance" reasons.  What nonsense.
metaverse
Copper - Posts: 210
Posted: November 18, 2004 at 10:31 AM / IP Logged
huh ? Nobody is telling you to get angry. Folks are telling you to go and have the installers get their act together and fix what is possible on your car since you were told otherwise. You can do it passive or aggresssive..your own will.
You are just looking for ammo to go back to the installer. It is understandable, but, do you think it would make sense that you are going to go stand in front of them and say "my friend xyz from the internet told me to hook up the RED / blue/white wire behind the stereo to make this work, just do it" ? And there is indeed a way to connect a proxy sensor with the shock sensor in parallel and have both work... The accessories such as heat/ac will have to see power to make them work. Looks like they either missed a wire, or, did something out of the ordinary. I'm glad you are giving them the benefit of doubt..hope it sorts out for you.
forbidden
Platinum - Posts: 5,354
Posted: November 18, 2004 at 1:18 PM / IP Logged
Here is my 1.64cents Canadian...... what the installers will need to do is diode isolate both the impact and proximity sensors, 4 diodes in total, one on each trigger line. Basically they will take the intrusion line and the preintrusion line and Y each line, on the ends of each Y is where the diode will go. Then each sensor can be hooked up to the proper line. The diodes are necessary to keep each sensor from interfering with each other.
For the remote start issue it sounds like they have missed a line. The heater is controlled either by an ACC or IGN circuit. Put the keys in the ignition and turn it to ACC, does the heater work? No, turn the ignition to on, does the heater work. It should work in either one or both of these positions. If it does, then they have indeed missed powering up an additional line like a 2nd ACC (rare) or 2nd IGN (more common).
