door lock problem 98 S10 blazer
charles bradfor
Posted: November 20, 2004 at 10:53 PM / IP Logged
Whenever it rains, the factory door lock relays continously trigger on this 98 S10 Blazer. It happens just sitting there or driving down the road. I have some experience (but not with Cheys) with the resistor trigger circuits and think it's posssible to be having crosstalk from the moisture in the doors to be false triggering the relays. Any experience with this problem? thanks, this is a great web site.
jrilla
Gold - Posts: 1,498
Posted: November 21, 2004 at 10:32 AM / IP Logged
Hmmmmm
Do you have an aftermarket keyless entry installed?
J Rilla
Owner/Installer
Hymer
Silver - Posts: 695
Posted: November 21, 2004 at 10:53 AM / IP Logged
If it only does it when it rains that is a pretty good clue, where did you tap the connection at? It could be just a strand of wire poking through the tape on your connection reaking all the havock
Hymer
charles bradfor
Posted: November 21, 2004 at 2:49 PM / IP Logged
Oh I forgot to mention that there is no aftermarket stuff installed here. So I haven't been into the door panels yet. I was trying to garner ideas from you guys before I tear into it. It may be as simple as the moisture guard is torn or unsealed. I didn't know if this was a regular problem with this car or if I have the only one that does it.
Hymer
Silver - Posts: 695
Posted: November 21, 2004 at 5:13 PM / IP Logged
Never heard of it before, but it sounds like a relay has a cracked housing or moisture is penetrating the factory connection some where. I don't remember where they are on that truck.. hmmm Blazers had it under the dash.., my guess would be to check under the hood at your relay box and just replace the keyless entry relays and or breakers in the fuse panel..
Good luck
