24v radio
Dilligaf
Member - Posts: 28
Posted: November 21, 2004 at 8:54 PM / IP Logged
the other day, my uncle asked me about a 24volt am/fm stereo for his track-ho. Does anyone know anyplace I can search for an am/fm stereo that requires 24volts, or an inverter I can use to replace his current stereo with an aftermarket hu? The current stereo only pics up am stations and theres never anything good on it. Any suggestions?
stevdart
Platinum - Posts: 5,816
Posted: November 21, 2004 at 11:34 PM / IP Logged
http://www.mastervolt.com/dcdc/index.asp
haemphyst
Platinum - Posts: 5,059
Posted: November 22, 2004 at 10:39 AM / IP Logged
LOVE the handle! I wonder if anybody ELSE gets it? 24v radio - Last Post -- posted image.
A less expensive option, and if you are only running a deck would be a three terminal fixed voltage regulator. The TO-3 versions are rated to 20 amps, i think, and MORE than adequate to run a deck. Or, you might be able to actually find a 24 volt stereo. Here is a forum I was able to locate on the subject. Check that out. I am at work, so I can't do much research, but there's a start...
kgerry
Platinum - Posts: 3,455
Posted: November 22, 2004 at 4:15 PM / IP Logged
Audiovox makes a 24V stereo system... we service them for the local equipment dealers... do a net search
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Mad Scientists
Silver - Posts: 380
Posted: November 22, 2004 at 7:55 PM / IP Logged
 He's probably running two 12v batteries in series on that track hoe.. just tap off one of the 12v batteries to get 12v.
Does It Look Like I Give A Flip?
Jim
Dilligaf
Member - Posts: 28
Posted: November 22, 2004 at 8:23 PM / IP Logged
Jim
yup, thats what DILLIGAF means...
Actually, he is running two 12v batteries in series, I'd forgotten all about just being able to run it off of one battery. Thanx for refreshing my memory
haemphyst
Posted: November 23, 2004 at 11:08 AM / IP Logged
of COURSE... If you are going to use this solution, make sure you connect the negative wire to the chassis, (obviously) but the positive wire needs to tap the wire BETWEEN the batteries... also, the remote CANNOT be connected to the ignition or accessory wire (if they exist), you just have to make sure the radio is always turned off...
