how to wire DVC subs
xs154
Member - Posts: 8
Posted: October 13, 2002 at 5:02 PM / IP Logged
i have two audiobahn 12's subs (entry level)....i was jsut wondering how should i wire them to a 2 channel  amp..the amp can handle two ohms mono but i want to run them at 4 ohms..ive looked at sites but none of it makes sense..any diagrams or help would be appreciated ..thanks
adrian
brianh
Silver - Posts: 518
Posted: October 13, 2002 at 5:38 PM / IP Logged
I need to know what the ohms of the vioce coils are?  brianh
rockfblaz
Member - Posts: 9
Posted: October 14, 2002 at 4:51 PM / IP Logged
read ohm's law to help you understand. Try to make yourself learn it. If it never makes sense to you...... you shouldn't be wiring things up yourself.
ih8u37
Copper - Posts: 54
Posted: October 14, 2002 at 9:08 PM / IP Logged
What model subs do you have? Are the voice coils 4 ohms each (I would assume so if they're entry-level)? How many watts RMS will the amp push per channel if run at 2 ohms stereo? How many watts can the subs handle RMS?
P.S. rockfblaz is correct that you should make yourself learn ohms law, but if don't get discouraged if it doesn't make sense at first. Keep working at it, & it will over time. & if you try & don't understand someone, ask for help with it. No sensible human will make fun of you for not understanding something if you're trying to figure it out, first, for yourself.
