98 dodge gran caravan remote start
airadam
Posted: December 11, 2004 at 9:34 AM / IP Logged
I have a JTI remote start A-10(JT start) that adds on to the existing keyless system. It requiresthree consecutive (-) pulses to activate the remote start. I have installed everything but I cannot find the wire on the lock or unlock side under the dash. can anyone help me out? or give me sugestions?
airadam
jay's detailing
Member - Posts: 24
Posted: December 11, 2004 at 10:57 AM / IP Logged
Airadam check this out I'm going to tell you how to this without resisters or relays. It works all the time ok.
 Now the wire you r looking 4 is the white and dk green wire under the fuse box ,the plug on the left. it call for a 1500ohm resister to lock and a 249 ohm resister to unlock or the other way around but listen to me, Go to the three relays behind or on above the fuse box. 1 will lock the driver door the 2nd will unlock the other doors and the third will lock all doors. now u will take 3 pieces of wire and do the following, on all three relay go to treminal 85 with the three pieces of wire wrap with wire around the trem and put the relays back. take the wire that locks the driver door and the relay that unlocks the rest of the doors and join them together connect that to the unlock of your remote start then connect your lock to the lock of your system and check your install... good luck (Angel)
mainormoscoso
Member - Posts: 41
Posted: December 14, 2004 at 7:32 PM / IP Logged
will this work on 96 gran caravan also? I hate using or looking for resistors, if it does the pulse that it needs is a negative pulse to those relays right?
Ravendarat
Platinum - Posts: 2,806
Posted: December 14, 2004 at 9:55 PM / IP Logged
That little trick works on just about any vehicle where you can narrow down the relays used for door locks. Anytime I do a car where you need to use resistors I always try to track down the relays first as its do much easier than the alternative. I believe your Grand Caravan has the identical set up to the 98 so you should be able to do it as well.
