98 nissan 240sx E-brake wire?
profuse007
Gold - Posts: 2,015
Posted: December 14, 2004 at 11:49 PM / IP Logged
i need to find this wire for RS on MT w/ compustar 2wss-as.
thanks.
Houston,TX
hagmanti
Silver - Posts: 304
Posted: December 14, 2004 at 11:57 PM / IP Logged
Wow-- nowhere to be found (in my sources, anyway).
I do have NSS - orange / YELLOW (-) @ gear selector switch.
Me
profuse007
Gold - Posts: 2,015
Posted: December 15, 2004 at 12:03 AM / IP Logged
theres a ebrake some where. i dont think theres a NSS on MT 240sx
thanks hangman
Houston,TX
cosmoworks
Copper - Posts: 144
Posted: December 15, 2004 at 1:26 PM / IP Logged
Yellow/Purple, found right at the parking brake lever after you remove the center console.
profuse007
Gold - Posts: 2,015
Posted: December 15, 2004 at 5:30 PM / IP Logged
got it:
Yellow/purple stripe, runs from console underneath the driver seat to the subharness, up the rocker panel to the SMJ just above the fusebox. From there, it spilts and goes to the cluster to trip the light, and out under the hood to the brake fluid reservoir.
Houston,TX
profuse007
Gold - Posts: 2,015
Posted: December 15, 2004 at 5:32 PM / IP Logged
thanks for the reply but i needed info w/o goin to the center console and test teh switch itself. i asked around in diff nissan forum and got the similar info you got.
Houston,TX
cosmoworks
Copper - Posts: 144
Posted: December 15, 2004 at 9:47 PM / IP Logged
That's also the easiest place to tap into it. Only takes a minute to remove the 4 screws that hold the center console in.
profuse007
Gold - Posts: 2,015
Posted: December 16, 2004 at 1:31 AM / IP Logged
the wire leads up to the dash, thats what i needed. i really dont like opening consoles when theres info floating around. not in hurry to install it anyways.
Houston,TX
cosmoworks
Copper - Posts: 144
Posted: December 16, 2004 at 10:38 AM / IP Logged
I see, but your original post asked "98 nissan 240sx E-brake wire?" and with the thread bumping sounded like you were in a big hurry to get to it as fast as possible.
Anyhoo, glad you found what you're looking for. I'm not familiar with the compstar unit, but you might also want to make use of the nuetral switch output since it's a manual tranny (to make 100% sure it won't start in gear).
ThurzNite
Member - Posts: 24
Posted: December 19, 2004 at 1:01 PM / IP Logged
Can you be more detailed on the SMJ? Thanx.
Jae
