bulb check problems
rsudbay
Copper - Posts: 68
Posted: December 21, 2004 at 4:03 PM / IP Logged
i can not find the bulb check wire and i have to finish this car today. the car is a 97 cheve cavalier. please help
hey, everyone has got to start somewhere. but ill learn
swamprat323
Gold - Posts: 1,335
Posted: December 21, 2004 at 5:39 PM / IP Logged
Waht do you mean by bulb check.
slicksam
Copper - Posts: 291
Posted: December 21, 2004 at 7:20 PM / IP Logged
i think he mean the bulb TEST wire.
it is on the ignition harness...I think there are 2 black thin wires.....it is the one that gives ground on CRANK postion.
Good luck
Testing is the key
rsudbay
Copper - Posts: 68
Posted: December 21, 2004 at 7:31 PM / IP Logged
they both have ground all the time. that is why i am confused. but could it be because i have the harnest unpluged
slicksam
Copper - Posts: 291
Posted: December 21, 2004 at 8:00 PM / IP Logged
if your talking about the ignition harness....test the wire when it is plugged...and one will give you a ground on crank
Testing is the key
slicksam
Copper - Posts: 291
if your talking about the ignition harness, yes plug it in. test the wire when it is plugged...and one will give you a ground on crank
Testing is the key
NowYaKnow
Gold - Posts: 1,217
Posted: December 21, 2004 at 8:08 PM / IP Logged
The ignition harness is a white plug and I think has black wires in pins E & F. These are not your bulb test wires. Is there a BLACK plug above the white plug? If so, the black plug has your bulb test wire in it. And as others have mentioned, the wire will read a ground while cranking.
Mike
