2001 Sierra Wire Diagram
Neolax1981
Member - Posts: 9
Posted: December 25, 2004 at 1:39 PM / IP Logged
Trying to install a remote start into a 2001 Gmc Sierra 2500 HD. Need a wire diagram for the truck. Please Help. Thanks in advance.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 30, 2004 at 11:19 PM / IP Logged
12volts red   +  ignition harness
Starter yellow   +  ignition harness
Second Starter
Ignition pink   +  ignition harness
Second Ignition white   +  ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition
Accessory orange   +  ignition harness
Second Accessory
Keysense
Power Lock lt. blue   +  brown plug at BCM
Notes: The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11.
Power Unlock white   +  brown plug at BCM
Lock Motor gray    drivers kick panel
Unlock Motor tan    drivers kick panel
Parking Lights+ brown    lt. blue plug at BCM
Parking Lights- white    lt. blue plug at BCM
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger    -  BCM
Use tan for the drivers door located in pin B4 of the purple plug, and for the passenger door it will be a orange in pin B2 in the purple plug or dk.blue/white in pin B11 of the lt.blue plug, must diode isolate these wires.
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm lt.green   -  drivers kick
Notes: Also found in the purple plug of the BCM.
Disarm No Unlock
Tachometer white    ECM
Notes: ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is at pin 20 in the connector labeled red. On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the red connector.
Diesel tach wire is white at the cluster.
Wait to start dk. blue  -  instrument cluster
Notes: See DirectFax document 1090.
Brake Wire white   +  brake pedal switch
Parking Brake
Horn Trigger black   -  brown plug at BCM
Memory Seat 1
Memory Seat 2
Memory Seat 3
2001 Sierra Wire Diagram - Last Post -- posted image.
Immobilizer Bypass Module:Required: YesType: Passlock 2Part #: 555L or 555T
mobileworks
Copper - Posts: 136
Posted: December 31, 2004 at 7:59 PM / IP Logged
Second ignition is a small gauage white wire and so is the yellow starter wire, test carefully.
Everything else is also at the bcm, door locks are in the far left plug, factory disarm is in the far right plug
and parking lights (-) are in the middle plug.
Brake wire can also be found at the ignition harness, white wire (+)
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
