Need Help with RS,car start and shuts off
gbedi
Posted: December 28, 2004 at 8:14 PM / IP Logged
Hi,
I need your assistance to troubleshoot what causes the car to shut off after a successful start with remote. I've CT3300 Prostart installed.  On 1st attempt car starts and runs for and 30 -50 sec. and shuts off, it then starts again the 2nd time, it runs for about 2-5 mins (time varies) and approx. same for 3rd attempt. I don’t experience this when car is started with key and idling.
No errors are reported by the RS module. RS is programmed to run for 15 mins.
Any help is much appreciated.
actionjackson
Copper - Posts: 59
Posted: December 28, 2004 at 9:13 PM / IP Logged
what kind of car
Jamie Jackson
*CRIMPING AINT EASY*
mykicks007
Member - Posts: 42
Posted: December 28, 2004 at 9:18 PM / IP Logged
Are you using tach wire ? or ?
gbedi
Posted: December 29, 2004 at 5:10 AM / IP Logged
The car is 95 Lincoln Continential ,  I'm using the tach  on wire connected to top of the coil to Dark Blue/Green and I'm reading 1.9v - 2.1V AC at the tach wire.
gus1
Gold - Posts: 1,013
Posted: December 29, 2004 at 9:37 AM / IP Logged
Try the other wire at the coil (yellow/white I think) DKBl/Green might be the ignition feed to it.
Gus
Craig3708
Copper - Posts: 155
Posted: December 29, 2004 at 12:35 PM / IP Logged
Tach  Signal:
ORANGE / WHITE
AT PIN 2 ON IGN CONTROL MODULE *
* Ignition Control Module Located On Driver Rear Of Engine Compartment On Fender Apron.
