97’ Toyota Avalon Remote Start?
dietz4ibanez
Posted: December 29, 2004 at 8:27 PM / IP Logged
I need a wiring diagram for remote start/keyless entry on a 97' Toyota Avalon...
  If you can help me it would be much appreciated!!! I wouldn't have to go to Best Buy and schedule an appointment to have a Christmas present installed!
Brian
snguyen
Silver - Posts: 281
Posted: December 30, 2004 at 9:10 AM / IP Logged
Toyota
Avalon
1996-1997
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
RED
IGNITION SWITCH HARNESS **
Ignition  #1:
BLACK/ ORANGE
Ignition #2:
BLACK / YELLOW
Ignition  #3:
N/A
Accessory:
PINK/BLUE
Brake  Light:
GREEN / WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLACK
AT ENGINE CONTROL UNIT *
Parking Lights:
GREEN (+)
# PIN CONNECTOR AT FUSE BLOCK
Headlights:
RED / YELLOW (-)
AT HEADLIGHT SWITCH
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Engine Control Unit (ECU) Located Behind Glove Box. ** Beginning in 1998, this vehicle is equipped with a transponder type of theft system. See Installation Note #144 - Bypassing Transponder Theft Systems.
Toyota
Avalon
1996-1997
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE/ RED & WHITE
OEM Alarm Disarm:
BLUE (-)
IN DRIVER KICK PANEL
Dome  Lights/Superv:
GREEN/ RED (-)
# PIN CONNECTOR AT FUSE BLOCK **
OEM Horn:
GREEN/ BLACK (-)
STEERING COLUMN HARNESS
Power  Lock:
GREEN/ ORANGE
# PIN BLUE CONNECTOR
Power  Unlock:
YELLOW/RED
IN DRIVER'S KICK PANEL ***
Trunk  Release:
WHITE/ BLUE (-)
AT TRUNK RELEASE SWITCH
Alarm  Input Wire:
GREEN/ RED (-)
Notes:
** Fuse Block Located In Driver Kick Panel. *** Child Safety Locks- L GREEN/ BLACK (-) In Same Connector As Door Lock Wires. See Note #209 - Child Safety Door Lock Diagram.
