tweeters horn vs dome
toytruck
Member - Posts: 20
Posted: January 03, 2005 at 6:51 PM / IP Logged
I was just wondering what the advantages/ disadvantages of the two were.  I noticed that most car audio has dome tweeters and home audio uses horns just wondering why?
DYohn
Platinum - Posts: 10,741
Posted: January 03, 2005 at 7:11 PM / IP Logged
HERE is a pretty good description of the differences between tweeters.  Most home audio uses domes too, by the way.  :)
Poormanq45
Silver - Posts: 597
Posted: January 03, 2005 at 10:03 PM / IP Logged
Well, it depends, are you refering to Compression Loaded Horn Tweeters?
If so, the major advantage they have it efficiency. In some extreme cases, horn loading a tweeter, or any driver for that matter, can increase the sensitivity 9Db
RockinF150
Member - Posts: 7
Posted: January 03, 2005 at 10:25 PM / IP Logged
I disagree. The great advantage from horns in vehicles is
1) allowing for more equal pathlengths among the most point source obvious frequencies (high freqs)
2) The primary advantage from horn loading is they are able to amplify the lower range of what the driver can reproduce. This makes achieving a good frontstage easier.
The cons of horns are
1) you will need a good 1/3 octave EQ to get very good results from horns
2) All horns leave a signature, no matter how slight .
I have owned USD 7.0s with full Rane processing, and MB Quart with only a stereo 1/2 octave EQ, and I will never go back to horns. Contrary to what is said about their installation, you need to be a master installer and physicist to achieve a good install and resemble factory equipment with HLCDs. Basically if you need to ask about them, avoid them, or be prepared to drop some cash with a proven, experienced installer(s).
Good luck on your quest.
By the end of the 3rd lap I saw Jesus so many times I started using Him as a brake marker.
toytruck
Member - Posts: 20
Posted: January 04, 2005 at 1:32 AM / IP Logged
Ok thanks for the input guys when i said home audio i mean to say like the big dj box speakers not really home audio and other than the cheap speaker/box kits at places like walmart i havent seen the horns installed in many cars so i was just wondering after someone told me they have a greater efficientcy. Thanks for the input i think ill stick with the dome tweeters hehe :)
