Remote start Pontiac G6 wire codes
solartech
Member - Posts: 28
Posted: January 05, 2005 at 11:06 PM / IP Logged
I am look ing for wire codes for a 05 Pontiac G6. Remote start codes and keyless entry.
snguyen
Silver - Posts: 281
Posted: January 05, 2005 at 11:25 PM / IP Logged
2005 Pontiac G6
Constant: RED / Black (+) Drivers kick panel - Harness to rear
Ignition: Pink (+) @ Ignition Switch
Starter: N/A (see note)
Accessory: Brown (+) @ Ignition Switch
Brake: White (+) @ Drivers kick panel - Harness to rear or @ Brake Switch
Park Lights Pos: Brown (+) @ Drivers kick panel - Harness to rear
Park Lights Neg: BROWN / White (-) @ Steering Column Harness
Horn: Tan (-) @ Steering Column Harness
Lock: White (-) @ Drivers kick panel (Single Wire System)
Unlock: White (-) @ Drivers kick panel (Needs a 1500ohm resistor)
Trunk Release: BROWN / White (-) @ BCM (Pass. side of center console)
Lock Motor: Gray (5wi) @ Drivers kick panel - Harness to rear
Unlock Motor: Tan (5wi) @ Drivers kick panel - Harness to rear
Door Trigger: Gray (-) @ BCM
Security Type: Passkey 3
Note:
Newer GM's has  no starter wire at the ignition harness the car knows to crank when it sees the ignition drop out. No need to hook your starter output to anything. Most important part is that the accessory wire needs to turn on BEFORE the ignition wire.
solartech
Member - Posts: 28
Posted: January 05, 2005 at 11:42 PM / IP Logged
how would i power up the accessory wire before ingnition ? With a -crimestopper 810 or rs 900?
