Installing ProStart CT-3300
whoever
Posted: January 10, 2005 at 11:30 AM / IP Logged
I'm trying to install a ProStart CT-3300 in a 1992 Toyota Camry, but can't figure out which wires to connect for the lock/unlock feature.  The wiring connections chart which I downloaded from Prostart/Autostart  doesn' seem right because I can't find the light green or light green and blue wires that are supposed to be in the blue connector behind the driver's kick panel.  Same goes for the lock/unlock wires indicated in the chart which I got from Vehicle information database here.  If anyone knows for sure which wires need to be connected and where they are located, I'd really appreciate a response because this is a Christmas present for my wife and my reputation as a hanyman is at stake.
Falcon 1
Copper - Posts: 130
Posted: January 10, 2005 at 12:56 PM / IP Logged
Here is some info.
Current Vehicle:
1992 Toyota Camry
Installing ProStart CT-3300 - Last Post -- posted image.
ItemWire ColorPolarityWire Location
12Vwhite - WHITE/ red+ignition harness
STARTERBLACK/ white+ignition harness
IGNITIONBLACK / YELLOW+ignition harness
ACCESSORYpink/blue *1+ignition harness
SECOND ACCESSORYBLACK/ orange+ignition harness
TACHOMETERblackcheck connector *2
POWER LOCKblue/white-passengers kick blue plug
POWER UNLOCKlt. GREEN/ red-passengers kick blue plug
PARKING LIGHTS +greenbottom of fuse box *3
PARKING LIGHTS -greensteering column
DOOR TRIGGERRED / white-*4
HEADLIGHTSRED / yellow-steering column
WIPERS
LF WINDOW UP/DNgreen - redAdrivers door switch
RF WINDOW UP/DNgrn/wht - RED / bluAdrivers kick panel
LR WINDOW UP/DNgrn/yel - RED / blkAdrivers kick panel
RR WINDOW UP/DNgrn/blk - RED / blkAdrivers kick panel
TRUNK/HATCH PINRED / white-light or sw. in trunk
HOOD PIN
TRUNK/HATCH RELEASE
FACTORY ALARM ARM
FACTORY ALARM DISARM
HORN TRIGGERGREEN/ black-steering column
BRAKE WIREGREEN / WHITE+bottom of fuse box *3
LOCK MOTORnonenonnone
UNLOCK MOTORnonenonnone
DISARM DEFEATnonenonnone
DISARM NO UNLOCKnonenonnone
DOME SUPERVISIONnonenonnone
SPEED SENSEnonenonnone
SUN ROOF OPEN/CLOSEnonenonnone
SUN ROOF LIMITnonenonnone
LF SPEAKERnonenonnone
RF SPEAKERnonenonnone
LR SPEAKERnonenonnone
RR SPEAKERnonenonnone
RADIO 12Vnonenonnone
RADIO GROUNDnonenonnone
RADIO SWITCHnonenonnone
RADIO ILLUMINATEnonenonnone
POWER ANTENNAnonenonnone
Notes:*1 Not required for remote start. *2 Located on the rear side of the passenger strut tower. *3 In a white connector just below the fuses with the wires exiting out toward you. *4 Remove black plastic air duct covering the top right side of the fuse box to access a 6 pin plug containing the RED / white.
Do it right the first time, only a doctor can bury his mistakes.
Craig3708
Copper - Posts: 155
Posted: January 10, 2005 at 3:58 PM / IP Logged
This car has child saftey locks. The lock wire from module goes directly to the Light Green in drivers kick panel and the unlock wire goes to two wires. The Dark green wire and the Child Safety Locks BLUE/RED in the drivers kick panel. Diode each one of these unlock wires to make it all work.
         Craig.
