2000 ACURA Integra GSr
shecret107
Member - Posts: 9
Posted: March 14, 2002 at 6:47 PM / IP Logged
Hello,
     Just purchased an alarm: Crimestoppers CS2000.  I have a 2000 ACURA Integra GSR. I've been trying to install this unit for 4 days, Im pretty stumped. These last couple of wires are troublesome for me. I don't know where to wire them into my car. Here are the wiring schematics of the module: http://www.crimestopper.com/index2.html . Just need to know where exactly to connect these wires to my car. HELP!!!! I've already checked out the diagram on this website, but doesnt say exactly where to wire them...Thank you for your time guys!!!
(-)  Horn Honk Output
(-) Dome lIght Illumination
(-) Hood/Trunk Input
(+) Door Trigger Input
(-) Door Trigger Input
Platinum - Posts: 12,488
Posted: March 14, 2002 at 10:32 PM / IP Logged
(-)  Horn Honk Output: BLUE/GREEN wire from ignition harness
(-) Dome lIght Illumination: GREEN/ RED wire in Driver kick panel
(-) Hood/Trunk Input : You have to install a hood pin switch into the engine area
(+) Door Trigger Input : NOT USED
(-) Door Trigger Input : Hook up to the door pin switch wire by the driver door sill
shecret107
Member - Posts: 9
Posted: March 15, 2002 at 5:08 AM / IP Logged
Hey Jeff,
     Thanks for the reply, I really appreciate it. I only have one more question. For the (-) Door Trigger, If this wire is connected to the driver door pin switch, won't the alarm only trip if that door is open.??? What about the passenger door??? Thanks AGain!!!
Posted: March 15, 2002 at 7:59 AM / IP Logged
The driver and the passenger doors are on the same circuit so if either one is open the signal goes to the alarm brain either way.
shecret107
Member - Posts: 9
Posted: March 15, 2002 at 11:34 AM / IP Logged
Hello Again Jeff,
     I hooked up the (-) Door Trigger to the Driverside pin switch, and the alarm only activated when that particular door is open. When the passenger door, or trunk is open, nothing...I've looked at thevehicle information database in this website, and it says to wire it to the dome light. What do you think??? The link is below: Thanks in advance, I'm 99% there thanks to you!!!
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=2000&make=Acura&model=Integra&ID=21&type=Alarm
wirewise
Moderator - Posts: 489
Posted: March 15, 2002 at 12:06 PM / IP Logged
You should be connecting to a GREEN/ Red (-) wire in the driver's kick panel or at the factory alarm for your door trigger. This will catch both doors. For the trunk you want to connect to GREEN/ Silver Dots (-) wire in the same location.
~~wirewise~~
FastCarNut
Member - Posts: 6
Posted: March 16, 2002 at 12:54 AM / IP Logged
He he, has anyone else noticed that the Crimestoppers CS2006 fm pager alarm is made by at least three other companies?
I have one in my Fiat that came from Commando but says it is a Delta!~  It works goo though for the most part!  Just dont have the range it is supposed to have especially if it is wet ouside.
"The tounge does not make a good test light..."
Posted: March 16, 2002 at 9:00 AM / IP Logged
The FM pager system that Crimestopper has is made by  the same company that makes the Vampire, Commando, Delta, Impulse, etc.......... There are about 10 - 15 different companies that have the same unit but under a different names. The manufacturer makes these alarms systems for whoever order's enough and they put their name on them and sells them as their own. Be warned though, the remote control is cheaply made and the range will diminish over time , that's what I found when we were installing these.
shecret107
Member - Posts: 9
Posted: March 28, 2002 at 2:49 PM / IP Logged
Hello EVERYBODY,
     I just want to say THANK YOU VERY MUCH to all of those who contibuted to this post, especially JEFF and Wirewise!!!!. I really appreciate your help. I finally had time to hook up the wires...and everything works GREAT!!!
Posted: March 28, 2002 at 11:09 PM / IP Logged
Good to hear that everything went well for you and your installation !! If you have any other questions about anything 12 volt post it here and some one will be able to help you out.
