'93 Cadillac Keyless Entry and Starter
fatgotti
Copper - Posts: 177
Posted: January 31, 2005 at 8:10 AM / IP Logged
I have a '93 Cadillac Sedan Deville  I am installing and Omega  Mars 22  keyless entry and car stater and I am not  experienced with alarms or starters  but this system has - lock and unlock outputs on it and my car has a positive pulse system if I am not mistaking how do I wire the locks and what other obstacles will I have?
Fatgotti    Yeah my name is John and I am FAT!! YEAH BABY
jaurora
Silver - Posts: 429
Posted: January 31, 2005 at 8:53 AM / IP Logged
Usally, the outputs on the module can be set for negitive(-) pulse and/or Positive pulse (+) Be sure that the outpust see a Positive (+) pulse and connect the lock wire from the module directly into the lock wire and do the same with the unlock wire. No relays will be required to do this operation,
MECP certified (If it really means anything)
Jeremy
Chimp
Member - Posts: 10
Posted: January 31, 2005 at 10:34 AM / IP Logged
If you can't set you alarm to + pulse out put you can always use the -ve puulse output and send it to a relay to switch a +ve supply.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 31, 2005 at 11:54 AM / IP Logged
Look on this site, for diagram how to wire a relay for poss. using a negative trigger
http://www.directechs.com/directwire/wire_body.asp?action=select&yr=2086&product=Remote%20Start
fatgotti
Copper - Posts: 177
Posted: January 31, 2005 at 1:06 PM / IP Logged
I have a diagram that shows how to wire a relay but it shows a coil between 85 going to 86 and a straight bar from 87a to 30 and I dont know exactly how it is supposed to be wired do I need special coils or what?  I know most of this is pretty dumb but I definitley want to learn how to do this...
fatgotti
Copper - Posts: 177
Posted: January 31, 2005 at 8:34 PM / IP Logged
Please anyone help me!!!!
Platinum - Posts: 12,488
Posted: January 31, 2005 at 9:14 PM / IP Logged
The straight bar is only showing you that the arm is connecteding pin 30 and 87a together when the relay is off. When energized, the relay will flip that arm to 87 and connect 87 & 30 together momentarily. Use this diagram to help you convert the (-) to a (+) polarity: http://www.velocitymotorsport.com/images/install_notes/N2P.jpg
fatgotti
Copper - Posts: 177
Posted: February 01, 2005 at 7:00 AM / IP Logged
Thank you guys.  Velocity Motors that diagram was way more simple then the one that comes in the manual Thanks a million...
Posted: February 01, 2005 at 9:42 AM / IP Logged
No problemo
