Need help finding tach wire
midnite97mm
Posted: February 06, 2005 at 1:57 PM / IP Logged
for xmas i received a (royal guard remote start/alarm system) and just dont know which is the tach wire help.
here is a link to one on ebay it has the wire diagram towards the bottom of the ad: http:///.com/ebaymotors/dll?ViewItem&rd=1&item=7950575341&category=33721.
thanks in advance
Albert..
KarTuneMan
Platinum - Posts: 7,056
Posted: February 06, 2005 at 3:28 PM / IP Logged
On the e-bay page...the seller claims to have "great" tech support. Thats who I would get ahold of.
That diagram is lame
profuse007
Gold - Posts: 2,015
Posted: February 06, 2005 at 3:43 PM / IP Logged
it doesnt seem to advertise tachsense, so prolly you only have voltsense (or selectable crank time)
Houston,TX
midnite97mm
Posted: February 07, 2005 at 6:18 AM / IP Logged
bobk wrote:
It is the purple wire just under the window roll up module on the last diagram. It is also a oil pressure switch voltage change, ground at key on only and 12v+ when the engine starts and oil pressure opens the switch. It's the 5 pin connector on the upper right.
Thanks Need help finding tach wire - Last Post -- posted image. bobk I was looking at that wire but was not sure if it was the right one.
And thank you all for the replys
Albert
red50
Posted: February 12, 2005 at 11:07 PM / IP Logged
Any luck with the alarm midnight? My friend bought one of these off of ebay but since the directions suck i had a question about teh relay and how to hook it up. Did you get this thing installed yet?
An answer would be extremely helpful...
Darren
midnite97mm
Posted: March 04, 2005 at 6:48 PM / IP Logged
Darren
Sorry for the late reply red50. Since I last posted I have yet to install kinda busy with new house remodeling and with work hav'nt had any time yet. But hopefuly some time this month I will install.
