How do eliminate engine noise.
techspeed2005
Posted: February 07, 2005 at 7:22 PM / IP Logged
I am have trouble to eliminate the engine noise after I install an amplifier in a car. I used a 4 guage power wire. I have the audio signal wire wiring up on the same side of the car.
Techspeed
cruelneo
Copper - Posts: 77
Posted: February 07, 2005 at 7:27 PM / IP Logged
i was told always to run on sep. sides and try a ground loop from rat. shack that might work they go on the rca's.
Francious70
Silver - Posts: 629
Posted: February 07, 2005 at 11:10 PM / IP Logged
Check this discussion on this very same topic. It's contriversial in that it says you don't have to run them seperately.
http://soundoff.phoenixgold.com/viewtopic.php?t=5552
Paul
bullman96
Silver - Posts: 294
Posted: February 07, 2005 at 11:57 PM / IP Logged
i personally disagree, i think that some people can get away with that, maybe even most people, but it is good practice to run them on other sides. if you are having problems with engine noise, that would be the first thing i would change. other than running your rcas on a seperate side, check you grounds and all connections. make sure all your wiring is clean. i almost guarantee that your issue is having the wires on the same side.
Pioneer PEH-9660mp
Mb Quart PCE-216 biamped
JL 12W6v2
Sony XM-4026 amp for tweeters
Kenwood KAC-7251 amp for mids
JL-4100 amp for sub
BaggedTruck
Member - Posts: 16
Posted: February 08, 2005 at 12:14 AM / IP Logged
well I am having the same prob...My RCAs are on the opposite side of my car as my Pwr wirw, AND I have a ground loop isolator installed, but im still getting engine noise.....im going to check my grounds with a DMM tomorrow, or could it possibly be other electrical components i have installed???
-Nick
Don't hop it...Bodydrop it
bullman96
Silver - Posts: 294
Posted: February 08, 2005 at 12:18 AM / IP Logged
how is your wiring set up, what amps do you have, and what deck?
Pioneer PEH-9660mp
JL 12W6v2
JL-4100 amp for sub
Ravendarat
Platinum - Posts: 2,806
Posted: February 08, 2005 at 12:47 AM / IP Logged
I have found that its very few times that engine noise is introduced from simply running the RCA's on the same side as the power wire. Its almost always a poor ground. Remember that even if a ground looks good, check it with a DMM because there are some vehicles that are just hell to get a good ground in, like J bodies
