avital 4300
ksingh
Copper - Posts: 62
Posted: February 12, 2005 at 2:02 PM / IP Logged
hey what s up guys i was wondering if the 4300 unit could be hooked up to either positive or negative doorlock system without using relay to reverse polarity
for ex: hondas are negative system and u will just hook the lock/unlock wires direct to the car
but on other vehicle s like a ford with a positive doorlock system would you need to reverse the polarity  or do the dei avital 4300 unit have onboard relays where i would just do the same as i would do the hondas just tie it straight into the car wires with out using relays to reverse polarity
Kenny
profuse007
Gold - Posts: 2,015
Posted: February 12, 2005 at 2:17 PM / IP Logged
what kind of car? some ford use 5-wires reverse pol, type A (+) 200mA, and TypeB (-) 200mA.
Houston,TX
ksingh
Copper - Posts: 62
Posted: February 13, 2005 at 10:10 PM / IP Logged
well i was just curious to know but i am working on a 1990 cadalliac brougham and the doorlock system is a positive type
i was told to just tie the wires in as i would normally do in a  negative system
but then i was also told to use 2 relays and reverse the polarity  so i was a little confused and no one seem to understand what i am saying so if you do please let me know thanks for your time
Kenny
secureauto
Copper - Posts: 197
Posted: February 14, 2005 at 12:12 AM / IP Logged
According to the install manual you can use
Green (+) unlock, Blue (+) lock on the 3 pin harness. No need for relays, unless if the doorlocks are 5 wire or if your installing actuators.
ASE Certified
