Dodge Intrepid 2004
gizmo29407
Posted: February 13, 2005 at 8:23 PM / IP Logged
1) My unlock works when I disarm the alarm, however, I cannot get the lock
to work when I arm the alarm?
2) Every now and then when I unlock the doors when I have remote started,
my windshield wipers do one cycle?
3) My headlights sometimes flicker when I have remote started. They also
come on solid when I have remote started I have no wires connected to the headlights, only parking lights. My cars headlights do
not automatically come on when the car starts with the key?
4) Even when the alarm is off, while driving down the road, the LED
flashes with every movement?
5) In all many of the wiring diagrams that I have seen, it states that the accessory wire on the starter harness is blk/orange. I have no such wire on the harness, which other wire can I use.
Thanks for any and all help. Mike
other wire can I use so when I remote start, my A/C will come on?
deezy
Member - Posts: 7
Posted: February 13, 2005 at 9:53 PM / IP Logged
Try a blk/white wire for the accessory wire
And for the locks if you didn't use resistors you should have
Larry
gizmo29407
Posted: February 13, 2005 at 10:35 PM / IP Logged
Thanks, I will try that for the accessory wire. What do you think about the other questions I had posted, are you able to help on those. Thanks
