790xv transmitter problems
karma
Member - Posts: 12
Posted: February 25, 2005 at 3:17 PM / IP Logged
Ok i know it's the typical problem with the 790xv and it's transmitter but i wanted to make sure the symptoms i'm experiencing are typcial of a broke remote.
 My remote is fully charged but out of no where it decided to only receive and will not send any commands.  Instead if i push a button it tries to contact the brain but beeps after a second or two alerting me that the command did not go through.  If i open the door the alarm goes off and the remote beeps to warn me that there is an intruder.  I cannot turn off or on the alarm through my remote but it is still monitoring my vehicle.
Does this sound like what happens when the 790vx transmitter breaks? is there a fix for it or do i need to just purchase the 791xv remote?  Do you think the remote needs to be reprogrammed? thanx
H-a performance
Member - Posts: 6
Posted: February 25, 2005 at 4:03 PM / IP Logged
did you try reseting the remote by pulling batt. in and out so everything on the remote resets??  I have seen a few problems not quite like yours but the reset has always worked for me. If not ship it out to get replaced.
karma
Member - Posts: 12
Posted: February 25, 2005 at 4:09 PM / IP Logged
does it sound like the remote may have been accidently reprogrammed?
vinman75
Copper - Posts: 63
Posted: February 27, 2005 at 2:12 AM / IP Logged
try to reprogram, if the remote doesn't relearn then it needs to be sent in. You may even have to pay a replacement fee. We had a good number of those remotes go bad and dei was just swapping them for the new ones but from what I hear we got charged for the last one we sent in that didn't even have scratches on it.
ccroadshop99031
Copper - Posts: 102
Posted: March 02, 2005 at 2:09 PM / IP Logged
i had this problem as im sure many of you did   if you unplug the antenna for about 10 - 15 seconds it works again
