viper 300esp ign door locks
Ben.c
Member - Posts: 29
Posted: February 25, 2005 at 8:41 PM / IP Logged
Could some one please help me turn off ignition cotroled door locks on a viper 300 esp .
 thanks
ozy installer
ken984
Copper - Posts: 78
Posted: February 25, 2005 at 9:44 PM / IP Logged
ok, make sure you have the door pin connected first..then turn the ignition on then off..then hold the balet button in until the alarms chirps once...then let off...then press it 4 times and after the 4th press HOLD it down..the alarm should chirp 3 times...now press button II on the remote the alarsm chould chirp twice indicating that you have turned the feature off. Let the valet button go and after 15 seconds the alarm will wail to indicate that programming mode is now off. Or you can turn the key on and that will end the programming sequence.
It is MUCH easier to do with a Bitwriter.
good luck
Ben.c
Member - Posts: 29
Posted: February 25, 2005 at 10:48 PM / IP Logged
Thanks heaps for your help. It was very much appreciated.  We couldn't find the install manual anywhere, as usual we have "put it somewhere safe".
ozy installer
