What is the best way to optimize imaging?
whiteblazer01
Member - Posts: 43
Posted: March 02, 2005 at 10:17 PM / IP Logged
I know this is an ongoing topic, but I want a bad ass setup in my car.  I want to be able to have optimal imaging.  How can I go about doing that?  Considering doing it right would be different for every car.
P.S.  I am also planning on putting in 6 12's (I know that will screw with the imaging, but how can that be incorporated?).
kfr01
Gold - Posts: 2,121
Posted: March 02, 2005 at 10:31 PM / IP Logged
Imaging.
*Good balance up front.
*Both left and right midrange and highs as equidistant from your ears as possible.
*Both left and right midrange and highs as on-axis as possible.
*Strong midbass up front to allow a low crossover point to the subwoofers.
*Tweeters as close to midrange drivers as possible.
*Close attention paid to the crossovers.
I've seen this correctly done in very few ways. The most popular and most often successful is this:
1) Kickpanel placement of both midrange and tweeter from a component set.
2) Dedicated midbass driver(s) in each door.
6 12's are going to make the sub-bass very hot.
You're going to need a lot of midbass work to blend with that. Try some quality 7" or larger midbass drivers in your doors.
New Project: 2003 Pathfinder
whiteblazer01
Member - Posts: 43
Posted: March 03, 2005 at 2:34 AM / IP Logged
where is the best place to aim each speaker?  Is there a best, or optimal angle?
kfr01
Gold - Posts: 2,121
Posted: March 03, 2005 at 5:16 AM / IP Logged
At your head. :-)
Seriously though, use that as a starting point and adjust from there. Friends holding and adjusting angles while you listen can help. Once you find a good angle note it and glass the kick around that angle. Repeat for the other side.
soundmasta
Silver - Posts: 246
Posted: March 03, 2005 at 7:50 AM / IP Logged
another thing that is useful is time delay.it makes things a bit easier and lets placement be comprimised a little. the eclipse 8454 that i have has the best time delay feature i've seen on a h.u., or you could find an external peice to take car of that.
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: March 03, 2005 at 4:28 PM / IP Logged
To completely optimize imaging you will need to move your seat position to the center of the vehicle.  Then remove all glass and hard surfaces.  After that, follow the directions the others provided from there.  Good luck! What is the best way to optimize imaging? - Last Post -- posted image.
Steven Kephart
Adire Audio
