Help with Crimestopper Window Modules
Pyromed1
Copper - Posts: 62
Posted: March 12, 2005 at 4:49 PM / IP Logged
Why does it keep doing this?
I typed the whole thing out and it still caused that mess.
Here's the manual:
http://www.crimestopper.com/techweb/InstructionBooks/ComboSystem/CS2011-2016%20REV%20B%20install.pdf
The Aux. Wires I have available are:
GREEN/ Red - bottom page 4
Blue/Black - Page 5
And
ORANGE / Black - Page 6
Any idea which one?
Corey
Pyromed1
Copper - Posts: 62
Posted: March 12, 2005 at 4:51 PM / IP Logged
Whew!!!! It worked.
Sorry
Kalus
Member - Posts: 16
Posted: March 12, 2005 at 7:20 PM / IP Logged
OK, it depends on how you want the windows to behave. If it was me I would connect one module (for windows down) to the Aux output. So, that is the Grey and Blue wires (for four windows ie. Circuit 1,2,3 & 4) of the roll-up module connected to the GREEN/ Red Aux output of the alarm. This way you can press your Aux button to roll down the windows. Another way would be to connect the front windows (Grey wire Circuit 1 & 2) to the Aux 1 output (GREEN/ Red) and the rear windows (Blue wire Circuit 3 & 4) to the Aux 2 output (Blue/Black). Leave both loop wires as they are (not cut) for momentary or pulsed input.
On the second roll-up module (for windows up), assuming that you want this to happen when you arm the alarm, connect the Blue and Grey wires on the module to the Green (-ve lock for doors). So, this way, when you arm the alarm, your doors lock and windows roll up automatically. Leave loops 1 & 2 on the window module uncut.
So that's about it... Pink to key on power, which will disable the module while the car is on, so u can't accidentally jam your friends head in the window.
Black to ground.
Leave Green and Yellow disconnected.
Pyromed1
Copper - Posts: 62
Posted: March 12, 2005 at 10:35 PM / IP Logged
Thanks Kalus!  Your awsome.
Corey
