2000 F150 Firewall Hole Location?
mrmsudawgs
Copper - Posts: 145
Posted: March 11, 2005 at 1:20 PM / IP Logged
Is there an existing hole / grommet where I can pass my amp's power wire through the firewall of my 2000 F150 Supercab? If so, where is it located? If not, where do I drill?
Thanks!
Mike
jt73
Copper - Posts: 81
Posted: March 11, 2005 at 4:56 PM / IP Logged
 i have a 2003 so it should be close....passenger side between kickpanel area and A/C...thats where mine is anyway
dwarren
Posted: March 11, 2005 at 5:13 PM / IP Logged
jt73 did you have any problems grounding your amps?
I recall hearing that grounding directly to the frame is necessary because the bodies of these trucks is not entirely metal, but rather a compsoite.
jt73
Copper - Posts: 81
Posted: March 11, 2005 at 5:43 PM / IP Logged
grounded to something on the body...but cant recall what...i think  it was the spot where the jack was.  or maybe a seat belt bolt...i will have to check, but no grounding problems though
