Clifford 2.5x not responding to remote
playr747
Copper - Posts: 65
Posted: March 25, 2005 at 3:10 PM / IP Logged
I just left work and got home and my alrm will not arm. I keep getting the out of range beeping from my 2 way remote. I tried to disconnect power to battery and cycle the alarm , no luck. Any ideas why my alrm would stop responding all of a sudden. Its been working fine for about 11 months. Its still too cold to go outside and dismantle the car to get to the brain. I am looking for ideas on what I can try for now.
thepencil
Gold - Posts: 1,526
Posted: March 25, 2005 at 6:29 PM / IP Logged
Maybe loose connection of the Antenna. Have you try putting in new battery on the remote? Use band name battery it's a lot better than the $1 for 4 stuff.
Be careful whose advice you buy, but be patient with those who supply it.Clifford 2.5x not responding to remote - Last Post -- posted image.
kgerry
Platinum - Posts: 3,455
Posted: March 26, 2005 at 10:16 AM / IP Logged
pop the battery out of the remote for 5 minutes and retry it.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
playr747
Copper - Posts: 65
Posted: March 26, 2005 at 11:53 AM / IP Logged
I have new battery in it. I use Energizer MAX. They seem to last the longest. I cannot get to th antenna connection at the brain due to the location right now. I would have to take my Seat out and what not. I will try to take battery out of remote for 5 minutes.
Thanks for all suggestions, if there are any other ideas let me know.
playr747
Copper - Posts: 65
Posted: March 28, 2005 at 2:35 PM / IP Logged
Anybody else have any ideas??
playr747
Copper - Posts: 65
Posted: May 02, 2005 at 6:28 AM / IP Logged
I cant figure this out. Does anybody have any similar experience.
JWorm
Platinum - Posts: 2,208
Posted: May 02, 2005 at 9:54 PM / IP Logged
Your remote probably needs to be replaced. They usually only last about a year. My first one lasted 14 months, but the one I replaced it with lasted a month before it stopped receiving notifications from the alarm. Today I programmed remote number 3 for it. I take very good care of the remotes, but they are fragil and do break.
Only suggestion would be to disconnect the antenna cable at the antenna for a minute. I've seen that fix the problem on occasion. if it doesn't, hopefully you bought the system from an authorized dealer that will replace the defective remote for free.
